Standheizung Höhenkit bis BJ 2013 - zweite Pumpe
05 Jan 2014 15:37 #41 von radim
This is always very interesting discussion ...
Let technical reasons to go and come to see the practical experience.
Once we have F13 on the display and like to run heater in normal order, we have few options how to run D4S again:
1. Descend to lower altitude than 1 500 m
2. Keep our position at current altitude, start the engine and use van heater to reach higher temperature inside the car or wait for morning sun, because in such conditon D4S will run only shorter time at maximal output what increase our chance to overcome critical heater's stage of 3500 W output. At lower stages F13 will not reached
3. Reduce inside tempareture such way, that targer ineterier temperature will be reached earlier than D4 will be overheated
If we follow point 1, even at altitude for example of 1 000 m or even much lower, we need to restart the heater 3 - 5 times, because only after so many restarts will heater work correctly (I talk about fast descend, because we are very cold inside the car and like to sleep).
Such restarts need 1 - 1.5 hour of our time plus time needed for descend.
If we follow point 2, or morning sun warm up the interior, heater will finally work correctly after many restarts every 30 minuts or so, but we are able to keeep our location.
This takes usualy whole night.
If we follow point 3, it only depends on the difference between inside and outside temperatures, sometimes is enough to decrease target interior temperature from 20 to 17 celsius and our D4S is happy.
This is only possible in temperatures up to -5, there is not chance to try it in -10 and more.
We can use the heater at 2 100 m over summer, but we can have a fatal problem on the same place in winter.
Always is needed to keep maximal heater's output period as short as possible anyway.
Only this way there is a chance to get over F13 without H-Kit solution.
By the way, If disconnect the air outlet pipes, heater will always run at altitudes over 2000 very nice ..... but this is useless ....
kind regards
radim
Dies ist immer sehr interessante Diskussion ...
Lassen technische Gründe zu gehen und kommen, um die praktische Erfahrung zu sehen.
Sobald wir F13 auf dem Display und gerne Heizung in der normalen Reihenfolge ausgeführt , haben wir einige Möglichkeiten , wie man D4S erneut ausführen :
1 . Abstieg zum niedrigeren Höhe als 1 500 m
2 . Halten wir unsere Position auf aktuelle Höhe, den Motor starten und verwenden van Heizung auf höhere Temperatur im Wageninneren zu erreichen , oder warten Morgensonne , weil in solchen Erhaltung D4S nur kürzere Zeit bei maximaler Ausgangsleistung , was zu erhöhen unsere Chance auf kritische Heizgerätes Stufe überwinden laufen 3500 W Leistung . Bei niedrigeren Stufen F13 nicht erreicht
3 . Reduzieren Sie innerhalb Tempareture solche Weise wird die Temperatur targer ineterier früher als D4 erreicht werden wird überhitzt sein
Wenn wir Nummer 1 , auch in der Höhe beispielsweise von 1 000 m oder sogar noch niedriger, müssen wir die Heizung 3 neu starten - 5-mal , denn nur nach so vielen Neustarts wird die Arbeit richtig Heizer (I über schnelle Abstieg zu sprechen, weil wir sehr kalt im Auto zu schlafen und wie ) .
Solche Neustart benötigen 1-1,5 Stunde unserer Zeit plus Zeit für Abstieg benötigt .
Wenn wir Punkt 2 oder Morgensonne erwärmen den Raum , Heizung endlich richtig nach vielen Neustarts alle 30 minuten oder so zu arbeiten , aber wir sind in der Lage, unseren Standort keeep .
Dieses nimmt normalerweise ganze Nacht .
Wenn wir Punkt 3, es hängt nur von der Differenz zwischen Innen-und Außentemperatur, manchmal ist genug, um Ziel-Innentemperatur 20 bis 17 Grad Celsius zu senken und unsere D4S ist glücklich.
Dies ist nur möglich bei Temperaturen bis -5, gibt es keine Chance, sie in -10 und versuchen.
Wir können die Heizung auf 2 100 m über den Sommer nutzen, aber wir können einen schwerwiegenden Problem auf der gleichen Stelle im Winter.
Immer erforderlich ist, um Ausgangsperiode so kurz wie möglich maximal Heizgerätes sowieso zu halten.
Nur so gibt es eine Chance auf über F13 ohne H-Kit Lösung zu erhalten.
Übrigens: Wenn die Luftaustrittsleitungen zu trennen, Heizung wird immer in Höhen über 2000 laufen sehr schön ..... aber das ist nutzlos ....
Herzliche Grüße
radim
2012 HD, 200 W solar system, Zoelzer roof system, Surfbox S-450, Fiamma F45i,
Espar High Altitude compensator (hohenkit no. 20 2900 70 00 07)
Some people feel the rain. Others just get wet.
05 Jan 2014 17:07 #42 von nogger
Hallo Radim
auch wenn ich mich wiederhole:
Der Fehler tritt nicht wegen Überhitzung auf!!!!!
Bei maximaler Heizleistung wird in größerer Höhe weniger Hitze produziert, da weniger Luftsauerstoff zur Verfügung steht.
Natürlich stimmen alle Deine geschilderten Punkte (möglichst schnell die Leistung reduzieren indem man eine niedrige Zieltemperatur einstellt usw. usw.). Der Grund hierfür ist aber nicht Überhitzung der Anlage sondern zu wenig Sauerstoff und damit unvollständige Verbrennung. Eine Reduzierung der Dieseleinspritzmenge durch geringere Taktung würde vollkommen ausreichen.
Und die Alternativen, wie nachts in niedrigere Höhen zu fahren, um heizen zu können - na ja.
Gut, daß ich bald wieder mit Gas heizen kann.
Gruß Nogger
09 Jan 2014 15:16 #43 von joeh
nach einer längeren Diskussion mit dem Bosch-Dienst habe ich mich letztendlich für das Höhenkit "zweite Pumpe" (Eberspächer Bestell-Nr.: 24 0222 00 00 00) entschieden. Es ist die einzige von Eberspächer offiziell empfohlene Lösung. Das Kit beinhaltet neben einer Pumpe noch den entsprechenden Kabelbaum, einen Umschalter und diverse Kleinteile für die Montage. Die zweite, neue Pumpe wird parallel (Treibstoff...) zur vorhandenen Pumpe geschaltet. Per Umschalter (montiert rechts neben dem kleinen aufklappbarem Fach mit Zigarettenanzünder...) wird zwischen Pumpe 1 (Standard-Pumpe des Nugget): 0 bis 1500m und Pumpe 2: 1500m bis 2750m ausgewählt.
Ich war zu Beginn der Diskussion nicht sonderlich von einer Lösung mit Schalter und zweiter Pumpe begeistert. Eine Sensor-Lösung wäre mir lieber gewesen. Allerdings hat die jetzt installierte Lösung auch einen Vorteil: die Komponenten sind simpel, leicht auszutauschen bzw. zu reparieren. Und, falls eine Pumpe ausfallen sollte, hab ich noch eine zweite...
Softwareanpassungen sind nicht notwendig. Reine Arbeitszeit: ca. 1,5h.
Der Einbau durch den Bosch-Dienst erfolgte schnell und sauber, auch auf Rostschutz (Pumpen, Schrauben, Kabeldurchführungen...) wurde viel Wert gelegt. Der entsprechende Mitarbeiter war definitiv ein Experte bzgl. Standheizungen.
Joeh
2012, HD, 140 PS
Folgende Benutzer bedankten sich: tourneo, Fränki, norge
09 Jan 2014 15:57 - 09 Jan 2014 15:58 #44 von Fränki
Hallo joeh,
vielen Dank für diese Info. Sehr interessant. Diese Möglichkeit ist wie Du schon schreibst die einzig wirkungsvolle.
Kannst Du mitteilen was es gekostet hat und wo hast Du es einbauen lassen?
Dankende Grüße vom
Fränki
Letzte Änderung: 09 Jan 2014 15:58 von Fränki.
09 Jan 2014 16:38 #45 von joeh
Hallo Fränki,
ich hab das Höhenkit bei der Fa. Eimer (Bosch Service) in Plattling (PLZ 94447) einbauen lassen.
Preis gesamt ca. 320€.
Zur Info: ich habe eben vorab das ok von Hr. Eimer Sen. für die Nennung des Namens bzw. des Preises eingeholt...
Auf der Homepage findet man auch den entsprechenden Fachmann für Standheizungen (Bosch Systemtechniker...). Ich selbst bin durch eine Empfehlung eines Bekannten auf die Firma gekommen.
Joeh
2012, HD, 140 PS
Folgende Benutzer bedankten sich: Fränki, norge
09 Jan 2014 16:44 #46 von Fränki
HI joeh,
das ist preislich doch einiges günstiger als bei mir im Umkreis Freiburg. Da muss ich mal drüber nachdenken. Es stehen so viele Kosten für den Nugget in Aussicht, das ich langsam Prioritäten setzen muss.
Fränki
09 Jan 2014 19:31 #47 von tourneo
Hallo Joeh ,
haben die den Kit auch bestellt oder hast du den woanders beschafft?
09 Jan 2014 19:49 #48 von joeh
Hallo Michi,
das Kit wurde vom Bosch-Dienst Eimer bestellt und eingebaut.
Viele Grüsse
Joeh
2012, HD, 140 PS
10 Sep 2014 11:02 #49 von Transition
kann es sein, dass das Höhenkit für die Standheizung bereits ab Werk eingebaut ist bzw. kann man das irgendwie am Nugget erkennen?
Ich stelle diese dumme Frage nur deshalb, weil wir im vergangenen Urlaub die Route des grandes Alpes gefahren sind und auch auf einigen sehr hohen Pässen übernachtet haben und die Standheizung ohne Probleme selbst auf dem Col de L'Iseran (höchster Straßenpass der Alpen knapp 2800 m hoch) fröhlich lief.
Nach den Aussagen die ich hier im Form gefunden habe sollte es doch ab 1500 m aufwärts Probleme geben oder?
Wir hatten ganz normalen Diesel getankt also kein Ultimate oder ähnliches.
Schöne Grüße,
Marcus
Nugget HD, 2012er Modell, Euro 5, 140 PS, moondustsilber, Fiamma Markise
  • Lacky
  • Lackys Avatar
10 Sep 2014 12:51 #50 von Lacky
Hi
Das wäre schön wenn der Kit eingebaut wäre. Also bei mir ist der bestimmt nicht drin (BJ2011).
Ich bin auf dem Furkapass mit 2436m zum pennen gestanden und die blöde Heizung
machte nach 10min. Laufzeit mucken und ging aus. Eine Fehlermeldung kam auch, weiß aber nicht mehr welche.
Das ist so ein Thema, wo ich beim Nugget voll sch*ise finde. :evil:
⚠️ Letzte Chance! ⚠️
