- Dank erhalten: 143
Ersatz für die Exide ES1600 Batterie
- radim
10 Aug 2026 16:28 - 10 Aug 2026 19:17 #31
von radim
I´m back from summer desert Marocco.
It was hard, to be honest sometimes very hard, much warmer than expected on Sahara, but Eco-Worthy worked very fine as @galli wrote.
If someone is interested, I can recommend this lithium battery.
No overheating, no problem with energy, no problem at all.
I would just improve a phone application, but for such low price I can live with.
Have a fine summer Nuggets.
Radim
2012 HD, 200 W solar system, Zoelzer roof system, Surfbox S-450, Fiamma F45i,
Espar High Altitude compensator (hohenkit no. 20 2900 70 00 07), Eco-Worthy 280 Ah LifePo4 battery
Some people feel the rain. Others just get wet.
radim antwortete auf Ersatz für die Exide ES1600 Batterie
I’m curious to see what you’re reporting after your Marocco trip.
Dankbare Grüße!
Radim
Letzte Änderung: 10 Aug 2026 19:17 von radim.
Folgende Benutzer bedankten sich: Burgi650, Greenhorn, norge, champawe, Tomcek
- champawe
- Dank erhalten: 4263
11 Aug 2026 11:15 #32
von champawe
Lg Andrea 😊
champawe antwortete auf Ersatz für die Exide ES1600 Batterie
Radim,
What have you done, to protect your fridge, from this heat?
Did it work well?
Did it work well?
Lg Andrea 😊
- Tomcek
- Dank erhalten: 5
11 Aug 2026 15:29 #33
von Tomcek
Nugget HD, Bj. 2012
Tomcek antwortete auf Ersatz für die Exide ES1600 Batterie
Hello Radim,
it's great to hear that you had a wonderful trip. However, those temperatures are definitely beyond what I would consider comfortable.
I wanted to ask if you could provide us with a detailed list of the components you had to replace or modify as part of the battery upgrade. I'm particularly interested because I also have solar panels on the roof and I'm still somewhat unsure about which components need to be changed or upgraded.
Thank you very much!
Tom
Tom
Nugget HD, Bj. 2012
- radim
12 Aug 2026 00:39 #34
von radim
Hi Champawe,
very good question !!!
Fridge was running for 6 weeks nonstop, but I had to increase the target temperature to 12 C from normal 6 C in desert areas, because it's indicator light was flashing, guess because couldn´t cool enough.
I was worried about the fridge many times, we wouldn´t be able survive without cool water (each drank about 7 liters a day), but somehow fridge kept cooling.
Much worse was to charge any electronic device, from phones to laptops, because it's overheating protection.
We found only way to charge devices to cool down them by AC ... and it helped well.
Kind regards,
Radim
Radim,
Did it work well?
Hi Champawe,
Kind regards,
Radim
- radim
12 Aug 2026 01:23 #35
von radim
Hello Tom,
asked Thomas (norge) before purchased LiFePo4 and read about his improvements here on forum.
No change in electrical system was done and everything is running well, just extension cables because of turned polarity.
BMS sends 40 - 45 A if charged by dynamo up to about 90% of battery capacity, then slows down to about 10 - 15 A and final 2 A respectively.
I just have purchased new Votronic solar regulator (MPPT 260 CI - Art. no. 1718) because my old Votronic was not optimatised for lithium charging curve and it's my primary source of recharging.
Really love Votronic solar regulators especially because of active coolling unlike for example Victron.
Have tried that and it helps very well in summer hot days.
I will probably install Fraron charger in the future for the same reason (lithium charging curve), but have used 230 V hookup once in last year before of winter trip only, so I'm not sure if is it needed.
Must think twice
If you like to try LiFePo4 in your Nugget I wouldn't be affraid of Eco-Worthy.
Price is fair as well as quality and what is important too - sits in Nugget perfectly.
You can always return back to Exide Equipment Gel - by the way good stuf too
List is as follows:
1. Votronic 1718 - solar regulator MPPT 260 CI - charging curve set to 14,4 V (there are four options)
2. extention cables 16 mm2 at you lenght, Amazon ASIN: B09KV7PZSP
3. connection points, Amazon ASIN: B0FVLVF6VC
If you have more questions please feel free to ask.
Good luck.
Kind greetings,
Radim
Tom
Hello Tom,
Must think twice
List is as follows:
Good luck.
Kind greetings,
Radim
Folgende Benutzer bedankten sich: norge, Keinhorst
- Friitz Bricco
08 Sep 2026 10:03 #36
von Friitz Bricco
Friitz Bricco antwortete auf Ersatz für die Exide ES1600 Batterie
Liebes Forum,
Da die bisher erwähnten BAtterien nicht mehr verfügbar sind (auch die EcoWorthy 280ah), bin ich auf eine 320Ah des Hauses HumsiENK mit ebenfalls passenden Maßen gestoßen (jedenfalls nicht größer als die Nennmaße der bisher genannten Batterien im Thread).
Gibt es bei einer derart hohen Dichte an Ah im Fach irgendwelche Bedenken oder Risiken?
Ansonsten sollte sich der einbau verhalten wie in bisherigen Beispielen im Thread.
Ich freue mich über eure Gedanken dazu!
Besten Dank!
Hier der Amazon Link:
www.amazon.de/HumsiENK-LiFePO4-Batterie-...h%2Caps%2C276&sr=8-6
Besten Dank!
- kiki
- Dank erhalten: 31
08 Sep 2026 15:11 #37
von kiki
Euroline AD BJ 2010 140 PS, 2 E, Nugget BJ 1989 AD 70 PS,2 E+3 Kids, Bulli T2 50 PS
kiki antwortete auf Ersatz für die Exide ES1600 Batterie
Hallo Friitz,
habe nach 16 Jahren 3 neue Batterien gebraucht, und diese hier bei Amazon bestellt, funktionieren tadellos:
3
ECTIVE - AGM Semi Cycle Batterie SC110 12V 110Ah 850A - Starterbatterie & Versorgungsbatterie wartungsfrei - VRLA Start- & Aufbaubatterie für Autos, Boote, Van, Camper
Christine
3
Christine
- SveaLOr
08 Sep 2026 18:49 - 15 Sep 2026 16:35 #38
von SveaLOr
SveaLOr antwortete auf Ersatz für die Exide ES1600 Batterie
16 Jahre mit gerade mal drei Batterien ist schon eine ordentliche Laufzeit. AGM-Batterien sind für solche Anwendungen wirklich praktisch, gerade wenn sie auch mal etwas entladen werden. Wichtig ist halt, vor dem Wechsel Abmessungen, Polanordnung und vor allem die passende Ladetechnik zu prüfen. Eine gute Batterie kann trotzdem für die jeweilige Anlage ungebaut sein. Übrigens, apropos handwerkliche Projekte zu Hause: Als ich neulich meinen Flur umgebaut habe, wollte ich etwas Warmes und Praktisches an der Wand haben, da passt so eine
massive Holzgarderobe für einen natürlichen Eingangsbereich
perfekt rein, um alles ordentlich aufzuhängen. Bei solchen technischen Geschichten im Haus ist eine gute Vorbereitung einfach die halbe Miete.
Letzte Änderung: 15 Sep 2026 16:35 von SveaLOr.
- kiki
- Dank erhalten: 31
11 Sep 2026 18:01 #39
von kiki
… unser Euroline fährt immer 3 Batterien ab Werk, 2 unterm Fahrersitz ( Starter und noch eine) und eine unterm Beifahrersitz, für den Innenraum.
Wollte nur sagen, das der erste Satz 16 Jahre gehalten hat.
Und natürlich
müssen sie passend sein.
Wir sind vor einiger Zeit mal liegengeblieben, Anzeige Motorsteuerung.
Der ADAC konnte mit seinem Diagnoseprogramm nix aussagen, aber hat uns gestartet.
Am Ziel angekommen gings dann nicht mehr mit dem Starten aber dank Ferndiagnose unseres Sohnes ( T6 Fahrer ), dass die Starterbatterie kaputt sein könnte und die Motorsteuerung dann nicht mehr ansteuert, konnten, nachdem wir die Spannung gemessen hatten und die Starterbatterie kaputt war, uns mit der anderen selbst starten.
Fanden wir praktisch.
Hilft vllt anderen
Christine
Und natürlich
Hilft vllt anderen
Christine
