- Dank erhalten: 8
12v part of the boiler not working
- Lee
01 Feb 2021 21:10 - 02 Feb 2021 08:43 #21
von Lee
Lee antwortete auf 12v part of the boiler not working
I checked. It's the original Elgena. Thank you
Letzte Änderung: 02 Feb 2021 08:43 von Lee.
- Lee
- Dank erhalten: 8
01 Feb 2021 21:15 #22
von Lee
Thank you. Yes I've just spent 4 hours troubleshooting the issue and this I think is the most likely problem. This Nugget stood in a Ford showroom where they weren't trained on it yet. I can see how this happened. I didn't turn it on without water. I watched all the YouTube videos and read the manual first before I used anything.
Thank you for your help.
01 Feb 2021 21:45 #23
Dolomiti antwortete auf 12v part of the boiler not working
How about the mainswitch?
Under the Kitchen.
Is it closed.
Under the Kitchen.
Is it closed.
- Lee
- Dank erhalten: 8
02 Feb 2021 08:42 #24
von Lee
The big red 12v main switch is closed. I mean the circuit is closed and all 12v appliances are working fine.
Thank you
Thank you
02 Feb 2021 09:57 #25
Hi, do you have a multimeter?
So you have to check the voltage at the fuse for the boiler.
If there is 12 volt you have to check it on the boiler.
And when you must remove the boiler.
It is incomprehensible when all the facts before the boiler are okay and it will not work.
Maybe the thermal fuse is broken how Voyageur has written.
I think it is possible.
You said something from the showroom.
So it is very possible that someone switched the boiler on and there was no water inside.
