- BeitrÀge: 18
- Dank erhalten: 8
12v part of the boiler not working
- Lee
01 Feb 2021 16:39 #11
von Lee
Lee antwortete auf 12v part of the boiler not working
Thank you for responding. The switch seems to be working fine as the boiler is working on 220V.
There seems to be only 1 power supply to the boiler. This looks like it has a 220V plug. I can't see any other power supplied to the 12V part of the boiler. Also I removed the fuse holder under the kitchen unit by the boiler but can't seem to get a the back if it as the wires are tight. Is this the correct fuse box or am I supposed to be looking at the vehicle fuse box?
Thank you again for your help.
- BeitrÀge: 4545
01 Feb 2021 17:01 #12
Dolomiti antwortete auf 12v part of the boiler not working
What does the nameplate say?
Is the Boiler original?
- BeitrÀge: 1042
- Dank erhalten: 1427
01 Feb 2021 17:19 #13
Ford Nugget, Bj.19
fdc4b6d566b95c01869c78a250028454 antwortete auf 12v part of the boiler not working
You have to unscrew the entire board on which the fuse box is located.
Ford Nugget, Bj.19
- Lee
- BeitrÀge: 18
- Dank erhalten: 8
01 Feb 2021 17:37 #14
von Lee
Thank you for that clarification. It seems I have to take the boiler out if the way to do that as it's blocking the top left screw . So before I do that big job can I please check this first? Does this fuse behind the board serve the 220v and 12V electric feed? Or just the 12v? I don't understand why the 220v is working if it's the boiler fuse that's faulty. Thank you for your help.
- BeitrÀge: 1042
01 Feb 2021 17:42 #15
Ford Nugget, Bj.19
The fuse is only for 12v.
Ford Nugget, Bj.19
- Lee
- BeitrÀge: 18
- Dank erhalten: 8
01 Feb 2021 17:47 #16
von Lee
A general question before I take things apart.
I have this Nugget for 2 weeks now from new. I think I should take it back to Ford and let them look at it under the warranty. If I take things apart it may invalidate the warranty.
Does anyone agree? Or does warranty not apply to the camper part of the van?
This is my first campervan so I'm still figuring things out.
Thanks for all the advice so far.
- Lee
- BeitrÀge: 18
- Dank erhalten: 8
01 Feb 2021 17:51 #17
von Lee
Thank you. That makes sense. I will try and remove that board without removing the boiler. Is this possible?
- BeitrÀge: 1042
01 Feb 2021 17:56 #18
Ford Nugget, Bj.19
If the fuse fixes the problem, you may have to pay for the repair yourself. Replacing the fuses is usually not covered by the warranty.
Ford Nugget, Bj.19
- Lee
- BeitrÀge: 18
- Dank erhalten: 8
01 Feb 2021 18:24 - 01 Feb 2021 18:25 #19
von Lee
Thank you. I checked the fuse and tested it and the fuse was all good đ.
The boiler still not working on 12v.
Letzte Ănderung: 01 Feb 2021 18:25 von Lee.
- BeitrÀge: 615
- Dank erhalten: 1109
01 Feb 2021 21:04 #20
von c25c868c58a98694421ea37238f2f6e5
c25c868c58a98694421ea37238f2f6e5 antwortete auf 12v part of the boiler not working
Hi Lee,
the boiler itself has two thermal fuses, one for 220 V and one for 12 V.
If the boiler is switched on without having been filled with water before these fuses will brake.
You can get a new thermal fuse by ordering it from ELGENA (-I recommend to buy 2 fuses so that you keep one as back-up; the fuse also comes with a replacement instruction.)
Kind regards
Voyageur
Kind regards
Voyageur
