12v part of the boiler not working
31 Jan 2021 23:02 #1 von Lee
12v part of the boiler not working wurde erstellt von Lee
Hello,
Can anyone help please?
I have a brand new Nugget Pop Top. The water boiler works fine on hook up and NOT on 12 V. I've read the manual 5 times and just can't seem to get it working on 12v.
Can anyone please provide some ideas of what I should check?
Thank you in advance for your help.
  • fdc4b6d566b95c01869c78a250028454
  • fdc4b6d566b95c01869c78a250028454s Avatar
  • Benutzer ist gesperrt
01 Feb 2021 01:02 #2 von fdc4b6d566b95c01869c78a250028454
fdc4b6d566b95c01869c78a250028454 antwortete auf 12v part of the boiler not working
Hello
Have you checked the fuse? It is behind the cover plate of the fuse box
Ford Nugget, Bj.19
  • 867f3d8312753693ccadbf7e537fe6c9
  • 867f3d8312753693ccadbf7e537fe6c9s Avatar
01 Feb 2021 07:42 - 19 Apr 2021 20:12 #3 von 867f3d8312753693ccadbf7e537fe6c9
867f3d8312753693ccadbf7e537fe6c9 antwortete auf 12v part of the boiler not working
Is
HD 170PS Automatik, Innendusche, 66 Liter Frischwasser, ausziehbarer Wasserhahn, KB6, Warmwasserthermostat, EcoFlow River, 130W faltbares Solarpanell, 2x Lifepo100AH DIN, Baimex Fahrerhausabtrennung, Rollen unter Sitzbank, SurftrÀger, 99% Dolomiti_Ladung mit Dunkel Modus.
Letzte Änderung: 19 Apr 2021 20:12 von 867f3d8312753693ccadbf7e537fe6c9.
01 Feb 2021 08:04 - 01 Feb 2021 14:13 #4 von Dolomiti
Dolomiti antwortete auf 12v part of the boiler not working
and when the two hints are okay so look at the backside of the switch.
Maybe the switch is damaged.
Because it runs a high amount of current about it.
And it is a question of time till it goes broken.
You can use a wire with two connectors to bridge the two terminals.
So you can check it if it works.
Sincerly, Maddin
Letzte Änderung: 01 Feb 2021 14:13 von Dolomiti.
01 Feb 2021 09:32 #5 von wonkothesane
wonkothesane antwortete auf 12v part of the boiler not working
And You will have to check the temp-gauges. For the 12V and for 220V branch there are separate temp-gauges on the upper part of the device that You have to set. Make sure both are set to max-temp! Had the same problem initially!
Sincerely Holger
01 Feb 2021 15:41 #6 von wingle1100
wingle1100 antwortete auf 12v part of the boiler not working
And if everything above does not work, check the thermal fuse. You may have blown it by using the boiler without water.
Regards
Kai
Nugget AD Plus Active, Frost-Weiß, 150 PS, Schalter, BearLock, Mike Sanders Hohlraum- Unterbodenkonservierung, 410 Wp Solar, Votronic MPP 440 CI, 360 AH LiFePo4, Votronic 50 A Ladebooster, BBX200Pro, 1500 W Wechselrichter, Sitzbank auf Rollen, Danhag Steuerung Standheizung, Teltonica RUT955 Router
01 Feb 2021 16:22 #7 von Lee
Thank you for responding. Yes the switch is on. The boiler is working on 220V. Just not working on 12V.
01 Feb 2021 16:25 #8 von Lee
Thank you for responding. Yes I have both set to max as the 220V part of the boiler is working. I've tested both directions of the 12V and it doesn't work clockwise and anticlockwise.
01 Feb 2021 16:29 #9 von Lee
Thank you for responding. I don't know where the thermal fuse is.
01 Feb 2021 16:36 #10 von fdc4b6d566b95c01869c78a250028454
Ford Nugget, Bj.19
