Zentralelektronik ausgefallen
  • van_campers
  • van_camperss Avatar Autor
  • Blech Nugget
20 Apr 2020 13:20 #1 von van_campers
Zentralelektronik ausgefallen wurde erstellt von van_campers
I have a 2015 Nugget High Roof. I've had it for two years and I've just taken it out for the season. However, just noticed that the display for the zentral-elektronik doesn't light up and the lights in the living space don't work. I have done the following checks:
- the red main switch behind the rear seat is turned on (hauptschalter)
- the RCD (fehlerstromschutzschalter) seems to be working
- fuses (sicherungen) for the 12 volt system are ok (the ones that are located next to the RCD)
I have connected the car to 230 volt and have been charging the batteries for a few hours (will do so for 24 hours) but the display is still not ligthning up and the lights in the car don't work even though the car is connected.
However, the water pump is working!
Does anyone know what the problem can be and how I should continue to search for reason to why it's not working?
Any help would be much appreciated.
Kind regards,
Malte
  • fdc4b6d566b95c01869c78a250028454
  • fdc4b6d566b95c01869c78a250028454s Avatar
  • Benutzer ist gesperrt
20 Apr 2020 14:02 #2 von fdc4b6d566b95c01869c78a250028454
fdc4b6d566b95c01869c78a250028454 antwortete auf Zentralelektronik ausgefallen
Diese Sicherung erneuern.
Ford Nugget, Bj.19
  • van_campers
  • Blech Nugget
20 Apr 2020 15:18 #3 von van_campers
van_campers antwortete auf Zentralelektronik ausgefallen
Thanks! I have changed all of them these fuses already but it doesn't seem to work anyway.
20 Apr 2020 15:28 #4 von Dolomiti
Dolomiti antwortete auf Zentralelektronik ausgefallen
Maybe you can check the fuses like in this thread:
www.nuggetforum.de/forum/technik-ab-2014...ronik?start=0#215117
Greetings, Maddin
20 Apr 2020 15:58 - 20 Apr 2020 16:12 #5 von fdc4b6d566b95c01869c78a250028454
If the display shows nothing but the water pump are working, it is because of the first fuse or the cable of the first fuse (loose contact)
Ford Nugget, Bj.19
Letzte Änderung: 20 Apr 2020 16:12 von fdc4b6d566b95c01869c78a250028454.
  • van_campers
  • Blech Nugget
20 Apr 2020 20:04 #6 von van_campers
I have checked again and when I first checked the water pump did sound when I turned the water tap but it seems as the voltage is too low so it can't actually pump any water. It seems to be working though but not enough power to actually pump any water. Maybe that is why the display doesn’t light up and the lights don’t work.
Therefore I think the batteries might not be charging even though I have driven the car and also connected it to 230 volt.
Is the next step to check the fuses and the battery condition under the passenger seat? Seems to be a bit of work to remove the passenger seat in order to be able to access the batteries so I don’t want to do this if it’s not necessary.
My german isn’t very good but I tried to find a thread here on the forum with instructions on how to remove the passenger seat to access the batteries but I wasn’t able to so if anyone knows of a thread it would be great if you could post a link.[/size]
  • Drei_im_Weggla
  • Drei_im_Wegglas Avatar
  • wall Camping ned worschd is
20 Apr 2020 20:58 - 20 Apr 2020 21:15 #7 von Drei_im_Weggla
Drei_im_Weggla antwortete auf Zentralelektronik ausgefallen
Hier ein Link zu unser-campingbus.de
www.unser-campingbus.de/energie-an-bord/...rie-computer/teil-1/
Bilder und Werkzeug
Torx-SchlĂŒssel TX 40,
1. Open four screws (Torx 40)
2. the Seat ist very heavy - der Sitz ist schwer
3. A second person should help to lay down the seat. Eine zweite Person sollte den Sitz mit umlegen.
4. The seat is stuck on the console. Pull back firmly on the backrest. - Der Konsolendeckel ist festgeklemmt - An der RĂŒckenlehne nach hinten ziehen.
5. Be carefull - Vorsichtig arbeiten.
Viele GrĂŒĂŸe Klaus
- aus dem frÀnkischen* Seenland Nord - Besatzung: B) + :kiss:
Letzte Änderung: 20 Apr 2020 21:15 von Drei_im_Weggla.
  • churrx
  • churrxs Avatar
  • Blech Nugget
  • FordNugget BJ 2014, EZ 2015, 125 PS, 2.2 L
09 Mai 2020 21:04 #8 von churrx
churrx antwortete auf Zentralelektronik ausgefallen
Moin zusammen.
nach mehrmonatiger Standzeit scheint in meinem Nugget die Elektrik nicht mehr zu funktionieren. Die zentrale Steuereinheit ist tot und erst dachte ich die Batterie hĂ€tte sich einfach komplett entladen. Aber auch nach lĂ€ngerer Fahrt und mit mit angeschlossenem Landstrom tut sich nichts. Die Sicherungen habe ich geprĂŒft bzw. ausgetauscht. Auch den Hauptschalter habe ich gecheckt. Das Licht und die Steckdosen funktionieren auch bei angeschlossenem Landstrom nicht. Komischerweise scheint die Pumpe zu funktionieren....
Habt ihr eine Idee was ich machen könnte bzw. woran es liegen könnte?
Vielen Dank fĂŒr eure Hilfe und schöne GrĂŒĂŸe
Stephan
09 Mai 2020 21:26 #9 von Dolomiti
Masse hast du auch ĂŒberprĂŒft?
Also unten am Beifahrersitz.
Die Kollegen haben auch schon gesagt, dass dort der Shunt sitzt. Der soll hin und wieder Stress machen.
PS: Ich glaube neulich hatte schon mal wer das gleich Problem. Hast du schon die Suchfunktion getestet? Ich schau spÀter auch noch mal.
09 Mai 2020 21:30 - 09 Mai 2020 21:44 #10 von kruti
kruti antwortete auf Zentralelektronik ausgefallen
Frage: warum wurden Sicherungen getauscht? Waren welche abgebrannt?
Wurde das Auto wÀhrend der Standzeit alle 4 Wochen geladen?
Ansonsten mal gem. Anleitung versuchen und erst den Motor an und dann 230 Volt stecken.
Wenn die Batterie zu sehr tiefenentladen ist, startet das LadergerÀt nicht mehr.
www.nuggetforum.de/downloads/BA_Nugget_ebook_de_2018_11_18.pdf
Bitte fĂŒlle deine Signatur mit Baujahr / Erstzulassung. Da gibt es seit 2014 Unterschiede.
Sicherungen unter dem Fahrer- und Beifarhrersitz sind auch ok ?
LG, Jens
Letzte Änderung: 09 Mai 2020 21:44 von kruti.
