- BeitrÀge: 184
- Dank erhalten: 141
Starlink Mini (permanent installation)
- radim
could you please advice me with permanent roof installation of Starlink Mini?
Have an interest to keep connectivity "In motion".
I would be gratfull for any tips.
Thank you very much in advance.
Radim
2012 HD, 200 W solar system, Zoelzer roof system, Surfbox S-450, Fiamma F45i,
Espar High Altitude compensator (hohenkit no. 20 2900 70 00 07), Eco-Worthy 280 Ah LifePo4 battery
Some people feel the rain. Others just get wet.
- geta
- BeitrÀge: 723
- Dank erhalten: 1272
you don't need a permanent installation.
Once you've correctly aligned your Starlink Mini under the Nugget's windshield, you can use it while driving.
The satellite connection remains active even while "in motion".
This works perfectly for me.
Gerhard
Nugget Plus AD 2022, 185 PS, Automatik, "Komplettausstattung", Strom-autark: Votronic-Booster 70 A, 300 Wp Wattstunde-Solar, 2.500 Watt Solartronic Wechselrichter an 300 Ah BullTron LiFePO4 plus BĂŒttner StandByLader Pro (lĂ€dt die Ford Batterien mit). Gas nie benutzt, da mit Induktion gekocht wird.
- radim
- BeitrÀge: 184
just want to confirm your words regarding satellite signal reception just behind the windshield.
I did a test on the 1600 km long way to Italy and Starink worked very fine for me even "in Motion".
Personally have a problem with too many wires inside Nugget, but will wait some time with fixed installation (have all componets purchased).
Thank you for your advice.
Radim
- Moesi
- BeitrÀge: 126
- Dank erhalten: 125
- Thank you for this interesting information.
- Is it possible to upload some pictures how a Starlink Mini under the Nugget Windshield looks like?
- If it is under the windshield: Does it really work while driving in any direction?
Und hier das gleiche in Deutsch:
âgeta schrieb: Sobald Sie Ihren Starlink Mini korrekt unter der Windschutzscheibe des Nugget ausgerichtet haben, können Sie ihn wĂ€hrend der Fahrt nutzen. Die Satellitenverbindung bleibt auch wĂ€hrend der Fahrt aktiv.
- Vielen Dank fĂŒr diese interessante Information.
- WÀre es möglich, ein paar Bilder hochzuladen, die zeigen, wie ein Starlink Mini unter der Windschutzscheibe des Nugget aussieht?
- Wenn er unter der Windschutzscheibe angebracht ist, funktioniert er dann wirklich wÀhrend der Fahrt in jede Richtung?
Viele GrĂŒsse, Moesi aus Vaduz
Nugget AD | 185 PS / Automat | EZ 11/2021 | mit AHK | Warmwasser | Mobilantenne und FunkgerĂ€t fĂŒr 70cm bis 80m (Amateurfunk)
Wollte eigentlich nur einen VW-Bus mit Tisch, Standheizung und Kaffemaschine und bin ĂŒber Umwege zum Nugget gekommen
- radim
- BeitrÀge: 184
my pleasure .... pictures follow ....
I have to say that like satellite technology for years, have experience with Iridium network, later with Garmin inReach (under Iridium) and definitely will be a fan of Starlink internet and even calling and reaching calls via wifi running over Starlink on places where is NO GSM/LTE coverage (must be active on phone and permitted by operator).
ItÂŽs gamechanger for me, IÂŽm almost able to avoid roaming fees in third countries and I can receive calls averywhere, and it works really perfectly with same fees as in home network (amazing !!!).
Yes, internet also works very fine with basic instalation of Starlink dish just behind the windshield, few minutes are needed on the startup, but somehow signal reception is perfect while driving (I had only few disconnects while driving through the forest under trees).
Starlink was connected via cigarette booster to cigarette plug and thanks to shorter wire purchased is wasnÂŽt so bad (extra accessories purchased on Amazon.de including the holder).
IÂŽm really very satisfied, my brother was able to be connected to office computer whole the way "on motion" (remote desktop connection).
With such connection you just want to avoid tunnels
Only problem I have discovered is forbidden "in motion inland" use in Spain (havenÂŽt tried, but will try in next days), but I can live with this piddling detail.
After return from Marocco I will make a final decesion regarding fixed installation, have all components ready, but if so, must drill an another hole to the roof and disassembly Zoelzer roof system and have no time for right now.
With kind greetings,
Radim
- Moesi
- BeitrÀge: 126
Thats amazing! Hard to believe that this works ... Ok, other than other Satellite Systems this Antenna can connect to many different Starlink Satellites at same time....
I may install this antenna as well. Does it need 30V??
Best regards
Stephan
- geta
- BeitrÀge: 723
Dazu gehören auch Kabel, die parallel mehrere AnschlĂŒsse bieten, wie etwa dieses
www.amazon.de/dp/B0DGKT74GR?ref_=ppx_hzs...t_b_fed_asin_title_2
das ich benutze (aber eigentlich zu lang ist) und viele weitere.
Einfach das Kabel in die 12-Volt-Steckdose stecken.
Sehr leistungsstark ist die oben neben der SchiebetĂŒr des Nugget, also diejenige, in die man auch die mitgelieferte Einsteck-LED-Lampe des Nugget steckt, um den Tisch zu beleuchten. Die ist auch dauerhaft aktiv geschaltet.
Aber Achtung: Starlink am besten immer nachts ausschalten, da die Antenne zwischen 18 und 24 Watt pro Stunde verbraucht.
WĂ€hrend der Fahrt ist das natĂŒrlich kein Problem. Wenn man aber nur die kleinen "Original-Nugget-Aufbaubatterien" von Varta als Wohnraumbatterie hat, dann werden diese ziemlich "ausgesaugt," wenn es dumm lĂ€uft. Also nachts besser ausschalten (einfach den Stecker ziehen).
Wie Radim schon schrieb, leuchtet, wenn der 12-Volt-Stecker in die Steckdose eingesteckt wird, das kleine blaue Licht auf der RĂŒckseite der Starlink Mini Antenne auf und es dauert 30 Sekunden bis maximal 2 Minuten, bis die Antenne alle Satelliten empfangen hat.
Dann mit der Starlink-App auf dem Smartphone die Antenne so lange ausrichten (drehen) bis sie perfekt ausgerichtet ist.
Das macht man alles im Stand (und jedes Mal erneut auf dem Stellplatz, um den bestmöglichsten Empfang zu haben).
FĂ€hrt man nun los, egal in welche Richtung, dann hĂ€lt die Antenne wĂ€hrend der gesamten Fahrt (auĂer in Tunneln, wie auch Radim anmerkt) einen sehr guten Empfang, der auch nicht abbricht.
Im Winter bin ich immer fĂŒr einige Monate in Spanien unterwegs (zuletzt 4 1/2 Monate), und zwar so lange, bis es in Deutschland wieder wĂ€rmer wird. Ohne die Wetterberichte (gerade bei den StĂŒrmen in Spanien) wĂ€ren wir aufgeschmissen, dank Starlink können wir den Sturmzonen fast immer entfliehen.
In RumĂ€nien und Norwegen wĂ€ren wir ohne Starlink an vielen Orten völlig aufgeschmissen, da es dort keinerlei Mobilfunkverbindungen gibt (wir stehen allerdings auch ĂŒberwiegend sehr einsam in der Natur).
Noch ein Hinweis: nicht nur in Tunneln, auch unter dichten BÀumen (z.B. im Wald) oder in engen Schluchten funktioniert Starlink nicht, da die Antenne eine "frei Sicht" in Richtung der am Himmel vorbeiziehenden Satelliten benötigt. Beim Einparken auf einen Stellplatz sollte man daher auch immer darauf achten, dass man, wenn möglich, Richtung Nord-West steht, um den besten Empfang zu haben (bis ca. 300 MBit/s).
Gerhard
momentan fĂŒr einige Monate in RumĂ€nien unterwegs.
- Moesi
- BeitrÀge: 126
Hab mir auch grad ein Starlink Mini Kit bestellt.
Zum Einen habe ich in meinem Nugget einen Beamer. Bei Dauerregen habe ich damit fĂŒr Netflix, Zattoo usw ein ziemliches Datenvolumen fĂŒr mein Smartphone im Ausland. Zum anderen habe ich meinen Nugget zu einem Funkbus ausgebaut (Ich bin Funkamateur).
Sollte es tatsĂ€chlich mal zu einem Ausfall der normalen Kommunikationsmittel kommen, wĂ€re ich funktechnisch bestens ausgerĂŒstet.
Falls dann Starlink noch funktionieren wĂŒrde, wĂ€re das natĂŒrlich auch eine Hilfe.
(Wobei ich denke, dass bei einem "Blackout" die Satellitensysteme ĂŒberlastet sein werden und ohne Bodenstationen auch nicht viel nĂŒtzen werden)
Lieferung ist in "1 bis 2 Wochen".
Werde berichten.
- Indianer64
- BeitrÀge: 31
- Dank erhalten: 52
VG Micha
Plus AD, 185PS Aut.,EZ 03.22, Euro6d, Sicht-Packet 3 mit Audiosys. 21, abnehm. AHKâŠ, LiFePo4 320Ah mit Ctek 120S Ladebooster, ECITVE Si 25 Wechselrichter, Starlink Mini, WS200SF+HV Solartasche, Victron MPPT 100/20, Flex Modul 375WP mit 100/30, Trelino M, Empaser Lautsp. + VertĂ€. Reif. 18" mit 235/55
- Eulenspiegel
- VerrĂŒckt? Nee, SpaĂ am Leben!
- BeitrÀge: 941
- Dank erhalten: 1749
dann sollte das ja wohl auch im HD funktionieren.
Oder spricht etwas dagegen?
Viele GrĂŒĂe Gustav
Nugget L1 HD mit 130 PS und 6 manuellen GÀngen, 5 GurtplÀtzen, 4 LÀngsbetten
