- BeitrÀge: 13
- Dank erhalten: 9
- Missing Safety net high roof Nugget <2013 - geometry of connecting points wanted / Sicherheitsnetz Hochdach Nugget <2013 - Geometrie der Verbindungsstellen?
- LuboKey
10 Jun 2021 18:17 #1
von LuboKey
Missing Safety net high roof Nugget <2013 - geometry of connecting points wanted / Sicherheitsnetz Hochdach Nugget <2013 - Geometrie der Verbindungsstellen? wurde erstellt von LuboKey
Dear Breave Nuggeters!
As I still can not find original safety net for my Nugget HD 2009 I decided to create my own DIY solution:-)
Please, could I ask owners of original solution to take and share detailed pictures of geometry of anchoring points?
It would be perfect to know measured dimensions of this missing articles of safety net, according attached (downloaded) pictures:
Bottom connection: T-shape profile which goes it to steel profile of unfolded bed
and
Side ones - black circular points, three on each side?
Is there any e-shop providing compatible counterparts to anchoring points for safety net for high bed?
Any info will help secure sleep of all my 3 kids,
thanks in advance,
Lubo
and
thanks in advance,
Lubo
- BeitrÀge: 6743
11 Jun 2021 10:18 #2
tourneo antwortete auf Missing Safety net high roof Nugget <2013 - geometry of connecting points wanted / Sicherheitsnetz Hochdach Nugget <2013 - Geometrie der Verbindungsstellen?
Hello,
Maybe it is easier and more stable to build your own frame without using original fitting points, see her:
www.nuggetforum.de/forum/13-umbauten/645...inderbett-mein-umbau
- LuboKey
- BeitrÀge: 13
- Dank erhalten: 9
11 Jun 2021 11:50 #3
von LuboKey
LuboKey antwortete auf Missing Safety net high roof Nugget <2013 - geometry of connecting points wanted / Sicherheitsnetz Hochdach Nugget <2013 - Geometrie der Verbindungsstellen?
Nice, do you have some photos with upper bed ready to sleep? (unfolded) How net is secured in position while sleeping? Thanks for info, Lubo
Folgende Benutzer bedankten sich: nugget_dir_ein
- BeitrÀge: 6743
11 Jun 2021 12:16 #4
Unfortunately not,
this is not my nugget, and the owner is no longer active here and sold his bus in the meantime.
- BodenseeNugget
- BeitrÀge: 1917
- Dank erhalten: 3445
11 Jun 2021 12:51 - 12 Jun 2021 10:11 #5
von BodenseeNugget
đšMeine Umbauten am BodenseeNuggetđ§ Auch fĂŒr die neuen Modelle interessant đ
BodenseeNugget antwortete auf Missing Safety net high roof Nugget <2013 - geometry of connecting points wanted / Sicherheitsnetz Hochdach Nugget <2013 - Geometrie der Verbindungsstellen?
For the safety of your children đ...
The measures are in PDF:
From which country do you come ?
Best regards Michael
AnhÀnge:
Letzte Ănderung: 12 Jun 2021 10:11 von BodenseeNugget.
Folgende Benutzer bedankten sich: LuboKey
- BodenseeNugget
- BeitrÀge: 1917
14 Jun 2021 09:51 #6
von BodenseeNugget
Fixed rods are sewn into three sides. The bottom is divided into three parts.
- LuboKey
- BeitrÀge: 13
- Dank erhalten: 9
21 Aug 2021 00:03 - 24 Aug 2021 11:02 #7
von LuboKey
Michael, thank you very much for info and drawings - with my wife we have crafted out this safety net:-)
Anchoring points are made of short steel rods 8mm, with 2 holles dia 3mm, head is made of 2pcs of washers 20x2mm, grinded to the original shape according to drawing and finally, all "bolts" hard coated by grey color.
Letzte Ănderung: 24 Aug 2021 11:02 von LuboKey. Grund: add the photos to the post
Folgende Benutzer bedankten sich: norge, BodenseeNugget
- BodenseeNugget
- BeitrÀge: 1917
21 Aug 2021 07:22 - 21 Aug 2021 07:23 #8
von BodenseeNugget
Hi LuboKey,
respect, looks very very good đ. How did you make the plastic fixings now, also look very good ?
P.s .: Would be great if you could add the photos to the post ...đ
You can do that with this button:
Letzte Ănderung: 21 Aug 2021 07:23 von BodenseeNugget.
