- BeitrÀge: 3434
- Dank erhalten: 3756
- French owner - Ford Transit Nugget 1989 looking for a gearbox
- lolofora
17 Apr 2015 17:31 #11
von lolofora
lolofora antwortete auf French owner - Ford Transit Nugget 1989 looking for a gearbox
Thank you very much for all your reply guys, i finally received today some pictures of the gearbox from the garage...
I am a bit upset about the quality though and i don't know how to understand the picture with teh serial number.
I am not sure as well if the pictures are good enough to fully identify the gearbox and the correct model.
I'd be happy to have your opinion on these if you can help
Do you think that if i directly write to the sites you gave me the owners would reply to me to help as well?
Thank you
Laurent
Thank you
Laurent
- lolofora
17 Apr 2015 17:59 - 17 Apr 2015 18:02 #12
von lolofora
I found on that english forum a guy talking about a ford transit gearbox:
found on that page:
fordtransit.org/forum/viewtopic.php?f=14&t=46599
The box looks very like mine eccept that it is inverted, he is talking about a "type 9 5 speed fitted to mk3 transits 1986-1989 before they introduced MT75"
I am just posting clues to see if that inspires any of you
Thank you!
found on that page:
Thank you!
Letzte Ănderung: 17 Apr 2015 18:02 von lolofora.
17 Apr 2015 18:12 #13
madmax antwortete auf French owner - Ford Transit Nugget 1989 looking for a gearbox
Hi Laurent,
regarding your pictures it seems like you had a 1986 gearbox inside your Nugget. The exact type is "849T 7A039 AB".
The first and only hit i had in different search engines is "www.aronparts.com". They have one on their stocklist but they're in Israel!?
It'll be the best if you contact the guys from the sides below and if they've none, they might have an idea if there's a possibility to change to an alternative type of gearbox or eventually they'll have another aftermarket partnumber for this type.
regards
Max
regards
Max
- BeitrÀge: 3434
17 Apr 2015 18:16 - 17 Apr 2015 18:20 #14
...so, you've been faster
In my opinion the english one from the picture above should be the right one. Drop him a mail and ask if it's an 849T 7A039 AB.
It's inverted cause they're sitting on the "wrong" side. But the rest should fit well except for the top of the box.
Max
Max
Letzte Ănderung: 17 Apr 2015 18:20 von madmax.
