- BeitrÀge: 464
- Dank erhalten: 602
- French owner - Ford Transit Nugget 1989 looking for a gearbox
- lolofora
I am looking for help in germany, i am the owner of a Fordt Transit Westfalia Nugget from 1989.
I absolutly love that Van but during our last trip te gearbox totally broke up.
The van is currently held in a garage 450 Km from our place and we are desperate to find for a gear box that will fit in our Van.
It's easy to find spare Gearbox for Ford transit from that period in France but apparently the Nugget requires a very specific gearbox.
So Westfalia being a German company i'am starting to look directly in your country.
I am looking for some advice or not beingable to speak german its relatively difficult to browse the web.
I was wonderring if you know guys some good website that could help us finding that gearbox.
Once again sorry for that english post i hope someone could help us in our research
Laurent
- lolofora
- ChristophUttner
- Carpe diem!
have a look at this homepage: gearbox
You can choose English as your language on the above mentioned HP.
Best wishes!
Christoph
FrĂŒher: Rad + Zelt, VW T4 Cali, AD, weiĂ, Bj: 91
01/2010 bis 06/2022 Nugget Baujahr 09/99, rot, HD, AHK, Sonnendach, SportgerÀtehalter, 2 x FahrradtrÀger, 100 WP Solaranlage, MPPT Laderegler, seit 07/19 Standhzg Planar 2D, 200 Ah LiFePo4 (01/21), seit 10/21 MB L 508 DG (Baujahr 1982), Selbstausbau
- lolofora
Thank you very much for that link! There is so many parts on that site and there look to be what i was looking for with that gearbox
I'll need to double check with the guy in the garage.
Thanks again
- BeitrÀge: 5397
- Dank erhalten: 7187
I cannot imagine why the Nugget should have another type of gear box than a "normal" Ford Transit. The point is the engine type, i.e. power output (turbo charged or not) and the year of construction. Your model should have rear wheel drive I suppose. In addition: every gearbox should have a label / badge fixed with rivets bearing the exact type / modell of the gearbox. Maybe you can contact the garage where your car is parked and they take a picture of the label (plaquette) and mail it to you.
Best regards,
RĂŒdiger
- lolofora
Thank you for your reply, yes i admit this is a mystery as well here, it's frustrating to struggle to find a gearbox for a so popular ford transit.
But i guess the garage is right and has no interest in saying all the gearboxes he found were not compatible.
As i said maybe that was still different chain assembly between germany and france... i really have no idea and as the van is now stuck 450 km from me it's quite difficult to have a visual understanding of the situation.
I wrote to the garage and asked for detailed pictures of the broken gearbox... i hope i'll have them next week.
- BeitrÀge: 5397
Hello,lolofora schrieb: I wrote to the garage and asked for detailed pictures of the broken gearbox...
pictures from inside are not really relevant (only rather interesting to look at, but no one will repair the inner parts of such a gearbox). More interesting would be pictures of the housing from several sides. This would enable you to find an adequate replacement (usually a second hand one/ occassion).
Before assembling everything (some time in the future) I would check the quality of the clutch plate (embrayage) and renew at least the disc.
Best regards,
RĂŒdiger
- BeitrÀge: 9363
- Dank erhalten: 10280
there's an adress in denmark - 'autoparts24' - unfortunately different prices in germany and france ...
.. but maybe those people could help you if you send them the VIN of your Nugget ...
Good luck and best regards
norge
- BeitrÀge: 9363
just another source for some parts around the older transit models - également disponible en français ...
Transitcenter
... again good luck
Regards norge
- Homo Transitus
- Ei guude
- BeitrÀge: 4451
- Dank erhalten: 4501
I know I'm a little late. But I read this just ago. If you still have no solution till now, you can contact Motomobil . They are one of the famoust specialists for old Ford cars.
Hope you will be sucessful.
Edit: Peut-ĂȘtre ici => Transit Forum France
GrĂŒĂe vom Homo Transitus
