- Dank erhalten: 3757
- Problem with the fridge / Problem mit der Kühlbox
19 Okt 2021 17:49 - 19 Okt 2021 17:51 #11
madmax antwortete auf Problem with the fridge / Problem mit der Kühlbox
campgrounds are always a posibility getting fresh water.
...if you'll find signs like this there might be also fresh water:
On your pictures above it seems like you're in germany, so you can use nearly every reachable public watersupply like at filling stations, recreational areas, cemeteries...
br
Max
br
Max
Letzte Änderung: 19 Okt 2021 17:51 von madmax.
- Gillestremblay
- Dank erhalten: 5
19 Okt 2021 18:04 #12
von Gillestremblay
Gillestremblay antwortete auf Problem with the fridge / Problem mit der Kühlbox
Yes I'm in Germany!
Once again thanks for the help. Really appreciated
