- Dank erhalten: 5
- Problem with the fridge / Problem mit der Kühlbox
- Gillestremblay
19 Okt 2021 13:32 #1
von Gillestremblay
Problem with the fridge / Problem mit der Kühlbox wurde erstellt von Gillestremblay
Hello,
I've just rented a 2020 ford nugget and I seem to have a problem with the fridge.
I put to 7 and I don't feel any cold at all. Even after 1 day running.
My voltage is at 12.7
I don't hear a compressor running, not sure if I should.
Also the 220V beside the back seat doesn't seems to be working. Not sure if it's linked. For this one, it might just be a problem with my adaptor.
I've tried resetting the red/green breaker. I didn't touch the other ones. (The user manual isn't in a language I understand, so it's hard)
Could it be the fresh water level?
Sorry for the question in English. I only speak French and English, and that's the only forum I've found. Hopefully someone can still help me!
- Dank erhalten: 3757
19 Okt 2021 13:48 - 19 Okt 2021 14:15 #2
madmax antwortete auf Problem with the fridge / Problem mit der Kühlbox
this might be your problem with the 220V part,
230V Main Fuse (the black/white switch on the right)
...and this "red bone" switch might be your problem with the fridge and the whole 12V things in the "living area":
Main switch 12V part
For reaching both fuses/switches easily you have to pull the backseat in front.
vg
Max
vg
Max
Letzte Änderung: 19 Okt 2021 14:15 von madmax.
- Drei_im_Weggla
- wall Camping ned worschd is
- Dank erhalten: 3296
19 Okt 2021 14:17 #3
von Drei_im_Weggla
Viele Grüße Klaus
Drei_im_Weggla antwortete auf Problem with the fridge / Problem mit der Kühlbox
Hello,
The second picture with the red switch is not the right one for your car.
The Nugget built in 2020 has the 12V switch near the fuse.
The compressor must run. Is it possible that you take a picture of the Westfalia Display?
Viele Grüße Klaus
- Gillestremblay
- Dank erhalten: 5
19 Okt 2021 14:40 #4
von Gillestremblay
Here's the pictures. At least I tried to upload. And you're right, the fuse system isn't the same. You can't see the cold is on.
The water level alert wasn't there in the beginning. I tried to flush the gray water and somehow it affected the fresh one?
Gillestremblay antwortete auf Problem with the fridge / Problem mit der Kühlbox
- Drei_im_Weggla
19 Okt 2021 14:46 - 19 Okt 2021 15:01 #5
von Drei_im_Weggla
Viele Grüße Klaus
Please check the fuse. It is the right one. Number 6 - Kühlbox (Fridge) 15 A (Ampere)
To you know how to check the fuse?
The error ! shown - the fresh water is low. That is not a problem, only a hint.
I don't understand why the refrigerator doesn't show an error.
If the compressor is not running, the workshop has to check it
(Sorry about my „rusty“ english)
Viele Grüße Klaus
Letzte Änderung: 19 Okt 2021 15:01 von Drei_im_Weggla.
- Gillestremblay
- Dank erhalten: 5
19 Okt 2021 15:02 #6
von Gillestremblay
No I'm not sure how to check it.
Is it the only 15A? I opened the plastic cover this morning in the dark and I'm not sure if I put it back in.
I should hear the compressor from the fridge running right? Because I can't hear anything at all.
Is there a place to find a workshop close to me? Because the westfalia website only gives 2 place to buy one...
Your English is perfect, thanks for taking the time to help me!
- Drei_im_Weggla
19 Okt 2021 15:08 - 19 Okt 2021 15:13 #7
von Drei_im_Weggla
Viele Grüße Klaus
To check the fuse, take it out. There must be a little window. There you see a thin wire. The wire must not be interrupted.
The compressor is in the right door under the fridge. It makes a humming sound - brrrm.
It is behind the black grid.
I atteched the manual - look at page 80.
Were you are? France - Germany?
Viele Grüße Klaus
Letzte Änderung: 19 Okt 2021 15:13 von Drei_im_Weggla.
- AvH
- Dank erhalten: 112
19 Okt 2021 16:56 #8
von AvH
Nugget HD Bj. 21, 130 PS, Solar; davor: Nugget HD Bj. 07, 110 PS; Besatzung: 👨👩👦👦 🐕
AvH antwortete auf Problem with the fridge / Problem mit der Kühlbox
If it is not the fuse, I would press the white plug in the right cabinet under the refrigerator (below the compressor) firmly together. In our case, it has a loose contact.
We only get an error message from the fridge when it is above 20 degrees. It might be too cold outside for that.
Folgende Benutzer bedankten sich: norge, Drei_im_Weggla, geta
- Gillestremblay
- Dank erhalten: 5
19 Okt 2021 17:21 #9
von Gillestremblay
That was the problem! Thanks! I just pressed the two white plugs together and it started to sing!
Thanks for your answers all, you saved my trip!
Also since I don't want to create a new thread for this... Where's the best place to fill the fresh water? An official camping place?
Cheers,
And thanks again!!!
Cheers,
And thanks again!!!
Folgende Benutzer bedankten sich: norge, Drei_im_Weggla, AvH, Dolomiti, geta
- Dank erhalten: 10310
19 Okt 2021 17:47 #10
norge antwortete auf Problem with the fridge / Problem mit der Kühlbox
Hallo Gillestremblay,
es kommt ein Stück weit darauf an in welchem Land du dich befindest und ob das Wasser aus dem Tank auch trinken möchtest.
In Deutschland und Ländern wie Norwegen, Schweden, etc. ist das Leitungswasser auch sehr gut ohen weiteres trinkbar.
In südlichen Ländern wie z.B. Italien oder Frankreich wird das Leitungswasser häufig so stark gechlort, dass man es zwar trinken könnte aber nicht mehr möchte ...
Auf Campingplätzen gibt es immer auf Möglichkeiten zum leeren von Abwasser und füllen von Frischwasser - du solltest dir aber den Schlauch dazu genau anschauen - nicht dass direkt vor dir jemand seine Toilette damit gereinigt hat ...
Da der Tank im Nugget nur ca. 40 Liter fasst, lässt er sich auch sehr gut mit einer (faltbaren) Gieskanne oder zur Not auch aus 1,5 L Wasserflaschen füllen.
Beim Nugget gibt es zwei Absperrhähne am Frischwassertank - beide müssen zum füllen geschlossen sein.
Hello Gillestremblay,
it depends a bit on which country you are in and if you want to drink the water from the tank.
In Germany and countries like Norway, Sweden, etc. the tap water is also very drinkable without further ado.
In southern countries such as Italy or France, the tap water is often so strongly chlorinated that you could drink it but no longer want ...
On campsites there are always on possibilities to empty waste water and fill fresh water - but you should look closely at the hose for this - not that directly before you someone has cleaned his toilet with it ...
Since the tank in the Nugget holds only about 40 liters, it can be filled very well with a (foldable) watering can or in a pinch from 1.5 L water bottles.
The Nugget has two shut-off valves on the fresh water tank - both must be closed for filling.
Greetings norge
Greetings norge
