- BeitrÀge: 184
- Dank erhalten: 143
- D4S heater / blower / control unit / burner compability
- radim
18 Jan 2026 18:15 #1
von radim
2012 HD, 200 W solar system, Zoelzer roof system, Surfbox S-450, Fiamma F45i,
Espar High Altitude compensator (hohenkit no. 20 2900 70 00 07), Eco-Worthy 280 Ah LifePo4 battery
Some people feel the rain. Others just get wet.
D4S heater / blower / control unit / burner compability wurde erstellt von radim
Hi Nugget friends,
I do a big servis of D4S heater after more than decade and have a following questions .....
1. Motor/blower original part = 25 2113 20 02 00 - do you know any source or may be replaced with 25 2113 99 20 00?
2. Control unit original part = 22 5101 00 31 02 - any idea where to buy or how to replace?
3. Burner original part 25 2113 10 01 01 - may be replaced with 25 2113 10 01 00?
Great thanks in advance.
Kind greetings
Radim
Kind greetings
Radim
- BeitrÀge: 9361
- Dank erhalten: 10277
18 Jan 2026 21:25 - 18 Jan 2026 21:27 #2
norge antwortete auf D4S heater / blower / control unit / burner compability
Hi Radim,
nice to hear you
1. Motor/blower original part => 252113200200
www.amazon.de/NIBOTT-GeblÀsemotor-252113...0DJ525T9B-&hvexpln=0
2. Control unit original part => 225101003102
standheizung-ersatzteile.com/steuergerae...-d4s-ford-nugget-wvc
3. Burner original part => 252113100101
www.standheizung-prokes.eu/brennkammer-a...100-252113100101-25/
Good luck and best regards
norge
P.S. ... and maybe a few pictures once you've successfully completed the maintenance ... ?
nice to hear you
norge
Letzte Ănderung: 18 Jan 2026 21:27 von norge.
Folgende Benutzer bedankten sich: radim
- radim
- BeitrÀge: 184
18 Jan 2026 22:46 - 18 Jan 2026 22:52 #3
von radim
radim antwortete auf D4S heater / blower / control unit / burner compability
Hi Thomas,
thank you very much for reply.
It seems that new part numbers are compatible
IÂŽm going to replace almost whole heater including the housing.
The most time consuming will be metal holder renovation, but looks terrible, rust took control over, therefore must sandblast it completly.
DonÂŽt you know where to get FLEXADUR hoses 90 and 75 mm cutted by one meter please?
I know only 4 m source, but it is too much for one repair and relatively pricely.
I have already the heater disassembled, there is one more D4 in my box. Original plan was to combine parts, but I decided to fully restore both.
THX .... Radim
THX .... Radim
Letzte Ănderung: 18 Jan 2026 22:52 von radim.
- radim
- BeitrÀge: 184
18 Jan 2026 23:55 #4
von radim
- radim
- BeitrÀge: 184
20 Jan 2026 20:35 - 20 Jan 2026 21:00 #5
von radim
Finally I decided for an original part, because have ordered all inner parts except for control unit from one vendor.
Actual number of D4S blower is 25214499200.
I dinÂŽt get any response from Berlin regarding control unit, but try to test my on diagnostic.
Hoses are on the way ....
In the meantime I have completed sandblasting of the holder and two layers of rost converter aplication (Wurth 0893110).
Not bad results, expect to have holder as new next week .....
Hi Radim,
nice to hear you
Letzte Ănderung: 20 Jan 2026 21:00 von radim.
Folgende Benutzer bedankten sich: norge, motom
- radim
- BeitrÀge: 184
22 Jan 2026 22:41 - 22 Jan 2026 22:43 #6
von radim
Unfortunately have discovered wire corrosion on intake air hose, what caused settled dirt on the blower.
IÂŽm very happy that all new hoses arrived on time and I can exchange whole ducting.
Passenger seat had to be dismantled ....
Letzte Ănderung: 22 Jan 2026 22:43 von radim.
Folgende Benutzer bedankten sich: norge, Batti
- radim
- BeitrÀge: 184
23 Jan 2026 19:26 #7
von radim
..... reassembling the heater ..... I like this work
.... next step = ducting ....
Folgende Benutzer bedankten sich: norge, chilango, harrymoppi
- radim
- BeitrÀge: 184
24 Jan 2026 16:06 #8
von radim
Mission acomplished ..... ducting took some time, but nothing to get over ..... job done ..... I have used stainless steel bolts M6x20 to fit holder.
75 mm ducting from "T" to the rear hot air output will be done in summer, because I must very urgently go to the Alps within few hour and enjoy new snow
One seat "decket" got unfortunately broken probably because wad frozen, therefore IÂŽm searching for new one.
If would you know where to ask for, be so kind and let me know please.
Folgende Benutzer bedankten sich: RudiRadlos, norge
- radim
- BeitrÀge: 184
24 Jan 2026 16:25 #9
von radim
- radim
- BeitrÀge: 184
24 Jan 2026 16:38 #10
von radim
Broken Roboplastic seat cover
