- BeitrÀge: 9
- Dank erhalten: 6
What's that?
- swissnugget
12 Aug 2014 22:57 - 12 Aug 2014 22:59 #1
von swissnugget
Hello every body!
Do you know what it is? It's under the passenger seat. I found it unplugged...
Thanks for your help!
What's that? wurde erstellt von swissnugget
Hello every body!
Letzte Ănderung: 12 Aug 2014 22:59 von swissnugget.
- radim
- BeitrÀge: 184
- Dank erhalten: 143
12 Aug 2014 23:08 #2
von radim
2012 HD, 200 W solar system, Zoelzer roof system, Surfbox S-450, Fiamma F45i,
Espar High Altitude compensator (hohenkit no. 20 2900 70 00 07), Eco-Worthy 280 Ah LifePo4 battery
Some people feel the rain. Others just get wet.
radim antwortete auf What's that?
I have a bit different colours of connectors (there are three), but if everything is running, this might be from the 12 V plug on left side of passenger seat .... check if 12 V plug is on ....
- swissnugget
- BeitrÀge: 9
- Dank erhalten: 6
13 Aug 2014 00:05 #3
von swissnugget
swissnugget antwortete auf What's that?
it's a good idea! but the 12v plug work normally... it's a mystery!
- radim
- BeitrÀge: 184
13 Aug 2014 07:19 - 13 Aug 2014 07:20 #4
von radim
Correct my post .... there are 4 connetors, 3 should be connected, one is disconnected (in my Nugget too).
See attached pictures if help - I have uncovered this place now, so easy to make a photo.
Red marked connector is normally for 12 V plug (not avaiable in my Nugget right now).
Letzte Ănderung: 13 Aug 2014 07:20 von radim.
- dgorell
- BeitrÀge: 27
- Dank erhalten: 35
16 Aug 2014 09:14 #5
von dgorell
dgorell antwortete auf What's that?
Maybe this is the connector for the seat-heating.!?!
