- BeitrÀge: 5
All batteries dead
- Jonteman
11 Jan 2026 19:01 #1
von Jonteman
All batteries dead wurde erstellt von Jonteman
Just bought a Nugget 12/2024 14000 km (new model) in Germany and drove it to Sweden. Camping batteries was 80% when we left and 1200 km later back home still 80%. Drove all the way in one push. Since then the car has been standing still in a warm garage waiting for registration. After 3 weeks the camping batteries was on 40%. Now after 3,5 weeks the car doesnât even start and no electricity at all. The company that sold the car mounted solar cells so they are brand new. What can be wrong? This is really strange.
- Michael123
- BeitrÀge: 549
- Dank erhalten: 445
11 Jan 2026 21:55 #2
von Michael123
N+ 2018 HD , 170 PS Automatik
Michael123 antwortete auf All batteries dead
Did you switch off all electricity before parking it in the garage? Even the display is consuming 300 mA so the batteries are empty after some weeks. The solar cells wonât help charging either without sunlight, of course.
- Mulkyway
- K.I. đ€ hilft beim Ăbersetzen.
- BeitrÀge: 307
- Dank erhalten: 230
12 Jan 2026 09:22 - 13 Jan 2026 16:54 #3
von Mulkyway
Mulkyway antwortete auf All batteries dead
Hi Jonteman.
Connect your Nugget to shore power as soon as possible. If the batteries are deeply discharged, theyâre probably damaged and need to be replaced.
Also...
Go to: campertouchscreen.com/
Read the manual but start at section 18: Using "Drive Mode"
Also be aware that when the voltage of the batteries for the living-area drops too low (less then 11,9V.), the SFB (Smart Fuse Box) will shut everything down.
When connected to shore power, charging of the starter battery stops once it reaches its maximum charge.
If your Nugget remains unused for a longer period, you need to unplug and reâplug the shore power every few days to reactivate the charging of the starter battery.
You should also know that the batteries for the living-area never reach a full charge while driving, and the solar system does not charge the starter battery.
A solution for this is installing a âbatteryâtoâbattery" charger which ensures that the starter battery and the batteries for the living-area are continuously charged, both from shore power and from solar power.
You drove 1200 kilometers at once... WAUW!
Kind regards.
Translated with Copilot. (Ăbersetzt mit Copilot.)âŹïž
SchlieĂe deinen Nugget so schnell wie möglich an den Landstrom an. Wenn die Batterien tiefentladen sind, sind sie wahrscheinlich beschĂ€digt und mĂŒssen ersetzt werden.
AuĂerdemâŠ
Geh auf: campertouchscreen.com/
Lies das Handbuch, aber fang bei Abschnitt 18 an: âDrive Mode verwendenâ.
Beachte auch, dass die SFB (Smart Fuse Box) alles abschaltet, sobald die Spannung der Wohnraumbatterien zu niedrig wird (unter 11,9V.).
Wenn der Nugget am Landstrom hÀngt, wird das Laden der Starterbatterie gestoppt, sobald sie ihre maximale Ladung erreicht hat.
Wenn dein Nugget lÀnger unbenutzt steht, musst du alle paar Tage den Stecker kurz ziehen und wieder einstecken, um das Laden der Starterbatterie erneut zu aktivieren.
AuĂerdem solltest du wissen, dass die Wohnraumbatterien wĂ€hrend der Fahrt nie vollstĂ€ndig geladen werden und dass die Solaranlage die Starterbatterie nicht lĂ€dt.
Eine Lösung dafĂŒr ist der Einbau eines âBatteryâtoâBatteryâ-Laders, damit sowohl die Starterbatterie als auch die Wohnraumbatterien kontinuierlich geladen werden â sowohl ĂŒber Landstrom als auch ĂŒber Solarstrom.
Du bist 1200 Kilometer am StĂŒck gefahren⊠WOW!
Liebe GrĂŒĂe.
Also...
Kind regards.
AuĂerdemâŠ
Liebe GrĂŒĂe.
Letzte Ănderung: 13 Jan 2026 16:54 von Mulkyway.
- Jonteman
- BeitrÀge: 5
12 Jan 2026 18:50 #4
von Jonteman
Jonteman antwortete auf All batteries dead
No electrical systems is on. Very strange to me that the car is dead after 3 weeks just standing still.
- BeitrÀge: 5416
- Dank erhalten: 7219
13 Jan 2026 10:54 - 13 Jan 2026 10:55 #5
RudiRadlos antwortete auf All batteries dead
Hallo Jonteman,
hier im Nugget-Forum pflegen wir u.a. höfliche Umgangsformen (z.B. Kurze Vorstellung und eventuell ein 'Danke' bei einer Antwort), - und die Umgangssprache ist Deutsch. Wenn Du Deine Frage auf Deutsch* stellst, wirst Du vermutlich noch mehr Antworten erhalten.
*Mittels eines Ăbersetzungsprogramms geht das ganz einfach ...
Hello Jonteman,
Here in the Nugget-Forum, we encourage polite behaviour (e.g. a brief introduction and perhaps a âthank youâ when replying), and the language used is German. If you ask your question in German*, you will probably receive even more replies.
*This was very easy to do using a translation programme...
GruĂ / best regards,
RĂŒdiger
Hello Jonteman,
RĂŒdiger
Letzte Ănderung: 13 Jan 2026 10:55 von RudiRadlos.
Folgende Benutzer bedankten sich: Kronzeuge, Mulkyway
