- Dank erhalten: 13
Rising Suspension
- Ale73
26 Sep 2023 12:07 #1
von Ale73
Rising Suspension wurde erstellt von Ale73
Hi everyone, I would like to have information on the possibility of raising both the front and rear axle. I know that unfortunately it is not a 4x4, but we often travel on secondary and dirt roads, the idea is to fit more resistant off-road tires and have greater ground clearance. suggestions, modifications and images relating to your transformations are welcome. I've seen that many people fit Goldschmitt air suspension at the rear, but what I would most like to know is how to raise the front, springs, spacers, etc...
Thank you all
Alessandro
Thank you all
Alessandro
Anhang wurde nicht gefunden.
- geta
- Dank erhalten: 1281
26 Sep 2023 18:44 #2
von geta
geta antwortete auf Rising Suspension
Ciao Alessandro
dai un'occhiata all'articolo
Spacer / Distanzscheiben zur Höherlegung Vorderachse
e traduci i post lì con Google.
Potresti trovare quello che stai cercando lì.
Gerhard
Gerhard
- Ale73
- Dank erhalten: 13
27 Sep 2023 08:31 #3
von Ale73
Ale73 antwortete auf Rising Suspension
Thanks a lot Gerhard.
